Very dangerously.I sent 277v to a lighting circuit and left the numeral and ecg disconnected and the lights work. 12v from the pole to earth and can't find the splice point how is it working???
Sent from my SAMSUNG-SM-G935A using Tapatalk
Couple of questions for clarity.It's a huge parking lot and I already looked for cut concrete
No 480 the ballast is wired for 277 and I was doing bucket lighting maintenance
Where did you disconnect neutral and EGC? At the fixture base of the pole, at the panel?I sent 277v to a lighting circuit and left the numeral and ecg disconnected and the lights work. 12v from the pole to earth and can't find the splice point how is it working???
I'm going to use a wire tracer but wanted to see if anyone could explain how the light is working with no return to the panel
