starbright28
- Minnesota
My dad and I were trying to figure out how the engineer was calculating different items for the exhaust fans on the roof.
here is the given information.
1/4 HP
single phase
115 Volts
It's a roof exhaust fan
Using Table 430.248 - full load currents in amperes, single phase alternating current motors.
from that table I get 5.8 amps.
Now here is how i was taught.
You take the 5.8 amps times 1.25% to get your total amps. (which is 7.25 A)
Then you take your total amps times your voltage - which I use 120v. (which is 870 watts)
This is the way the engineer did it:
he took the value from the chart - 5.8 amps. Then he took 115V times the 5.8 amps to get 667 watts.
He listed the 667 watts on the panelboard schedule as so, with a power factor of 0.8 percent.
Is this correct?? Are you not supposed to take the 125%? What voltage are you supposed to use, the 115V or 120V?
Please help.
1/4 HP
single phase
115 Volts
Please help.
