davidselectrical
I have recently completed an basement renovation. In the main area of the basement the customer simply painted the concrete walls and floor. All of the wiring was run in conduit along the outside walls. The customer has a utility area that does have GFCI protection for the recepticals complying with 210.8(A)(5). The outlet spacing does comply with 210.52 in the main areas (pool table/ Theater/ etc). The inspector is saying that the main area needs to have GFCI protection because the floors do not have carpet or tile so the room is concidered unfinished. I can not find that definition in the code book. I feel that the room is concidered a habitable room, how the customer decided to finish the walls and floor should not be an issue. The inspector said that he will respect your opinion on this matter.
thank you
thank you
