Fordean
- New Jersey
- Electrical Contractor
I was told to Put a GFCI at first receptacle. Instead of hiding these buggers all around House. I did the GFI breaker solution Much neater. Problem is how you test if they work. When a conventional GFCI Plug test trip button only works with grounded Wiring types Stump. Inspector said to Install GFCI since owner change all to 3 prong devices.
