I have kind of a weird one. There are these portable power stations used for connected welders and drills in an industrial outdoor environment. Each of them have a 480-208/120V step down transformer. My thought is to provide a ground rod in a well where they can set up the grounding electrode system for the separately derived 208V system. The 480V connection is done with a pigtail connection at a 480V disconnect and the intent is for them to bring the equipment ground along with this feed to this "substation". I know that what will inevitably happed is they will try to ground the 480V side to the driven ground rods. Fundamentally, it just seems like a ground fault would just use the earth as a path back to the service GES. I can't see anything wrong with it. What code issues would disallow this?
