Can cable be supported and secured by a right angle unistrut on-site made attached to a wall (like cable racks in a manhole) and/or by unistrut trapeze from the ceiling? The cables would be single conductor 500 MCM cables supplying power to high voltage magnets (1,000 VDC-1,800 VDC / +500/-500 to +900/-900 VDC). The cables would be located in a tunnel to where the tunnel is only accessed when the cables are de-energized and also the system has ground fault protection and overcurrent protection. This installation would be at a R&D site for the Department of Energy. The main question, is this type of cable support system recognized by the NEC and/or does this situation even fall under the jurisdiction of the NEC. If not what jurisdiction would it most closely fall under (NESC, IEEE, ...)? Thanks.
