joe tedesco
- Boston, Massachusetts
Is Support Required Here?
How so? Under the 2005 code it requires support and also under the new rule in the 2008 code because it has a coupling. The new rule requires that the conduit be "unbroken" if you want to delete the supports.If you leave the code alone, it will not require support.
don_resqcapt19 said:Ryan,
Don
joebell said:I'm confussed, why would this need to be supported in the 2005 code if the distance between to two disconnects is less the 3 feet or is the key word I am missing "within"?
Yes the new rule is less stringent, but I wonder about enforcement now that we have a rule. In many areas the inspectors were permitting what you proposed, even though it was a violation.Although I don't like what CMP 8 did to this proposal, it is still less stringent than the code was before.
ryan_618 said:Because there is no support...CMP 8 has routinely stated that raceway connectors are not a point of support. With that said, every installation of conduit that didn't have a support was a violation.
