Unusual Buchanan Cover
480sparky
Iowegia
Did a service call today in a dwelling to track down the cause of a breaker tripping.
I found these rubber covers over the Buchanans used during the original make-up.
I had to take 3 slices apart to isolate the offending cable. I stuck the caps in my pocket, and this evening I duplicated what I found in these photos: It appears, after the Buchanan was installed, that one part of the 'cap' was pulled over the splice:
The other cap was pulled between any number of the wires:
And pulled over the top of the first cap, to secure it:
I have never seen these before. Anyone know anything about them?
They were real popular in my area, the Twin Cities Metro, in the mid 1900s. I see them pretty regularly when working on splices made in that period. I think the boots were more popular, then, around here, than tape. . . but that is only my in the field informal observation.
Yep those Wrap Caps are still available in the Buchanan catalog. What I like more are the plastic Splice Cap Insulators but they are hard to find.
Makes for one heck of a strong connection if you need something stronger than a wirenut... like in a high vibration environment.
http://i214.photobucket.com/albums/cc172/480sparky/Construction%20methods/DSC_2650a.jpg
[IMG]http://i214.photobucket.com/albums/cc172/480sparky/Construction%20methods/DSC_2651a.jpg
[IMG]http://i214.photobucket.com/albums/cc172/480sparky/Construction%20methods/DSC_2652a.jpg
I have never seen these before. Anyone know anything about them?[/QUOTE]
A nickname for them is "Rubber Diaper".
Ideal* made them also, have a couple boxes ratholed.
* These predate Ideal's purchase of Buchanan.
I don't see many of these type - but there was a time where I would have occassion to demo out another slightly older type - a simular rubber boot, with a twist-on back-a-lite cap. A kin to these (and I wish these would come back!) was a brass ferrel with a set-screw type connection, and a threaded bake-a-lite cap.
I find these, in my area, in obviously DIY wiring. Easily 90% of the splices in them are loose.
I find those once in a while, I agree, they seem like a decent designed product...
they look ilke a crimp-on splice but its a two piece connection... you use a buchanan crimp and then slide the plastic cap over it. wont come off, it has one-way metal tabs that only let it slide on one way.
I've seen them as one piece, and you crimp right through the plastic.
With those - I rarely find any 'loose' - which is defined by what? (Yet to have found one that failed - i.e. had been arcing or intermittent) On the other hand - when I find Buchanan's of the crimp type I rarely find any done correctly - many of those are 'loose' by my definition of the term. Often where conductors could easily be pulled out, or had connections that held for 5-6 years - then started to arc, becoming intermittent. (I don't see them installed on circuit wiring any longer.*
IMO it is much like pre-twisting, or not pre-twisting in wire-nut applications. Again IMPO, that pre-twisting is far superior ('tighter') and is a much better connection - however not required by code, or by the manufactures themselves - but it is a 'tighter' connection than a 'looser' fit of not pre-twisting.
Is a Wago tight or loose? Depends on opinion I say. I would say they are loose....
*Are Buchanan's even allowed on circuit wiring any longer?
It's been a while......
but I recall one of my mentors using these on small motor connections that were crimped. Haven't seen one in years and never had the ocassion to install one.
In my area both the set screw with the twist-on bake-a-lite caps and the crimp-on with the rubber boot are very common in the older houses. 1940's - maybe 60's. The splices were twisted first then capped with one of those.
Unless they were soldered and then taped..... with the most horrific rubber tape covered by a cloth tape. The rubber tape left black goo on your hands for days.
