karl riley
Re: Unusual Problem
Please consider that a loop circuit, allowing neutral to split and go back both ways, can create a huge magnetic field in a large area.
I saw the results of a distribution loop in a circular subdivision in Florida where two lines fed the subdivision. The ends of the lines (underground) were across the street from each other, and so they bonded between the neutrals, causing a large magnetic field in the subdivision. The utility did not want to discuss it.
I do think the loop is a parallel path and violates 310-4.
Karl
Karl
