Grouch1980
- New York, NY
I'm working on renovating an existing duplex apartment... it's in a 2 family townhouse. The architect is only adding 2 new receptacles. And we're also adding a new central AC system (split system). However, there's areas in the apartment where the receptacles are spaced more than 12 feet apart. Does the addition of 2 new receptacles trigger upgrading the receptacle requirements in the rest of the apartment? Is there a threshold that triggers upgrading the receptacle layout in the whole apartment? If so, is there a code section that mentions this? I was told if you upgrade 50% of the wiring (or receptacles?), that's the trigger to upgrade the entire space.
Thanks everyone!
Thanks everyone!
