URD direct burial to from house to outbuilding
Greg1707
Alexandria, VA
Business owner Electrical contractor
I happened upon this installation. URD with a separate THHW conductor are direct buried in a trench to an outbuilding with a main panel inside the structure. Is this the best option? Is there a USE cable with four conductors available for this situation?
ptonsparky
Electrical Contractor
The THWN is fine if that is conduit all the way, but not for DB as you've indicated. I've buried a separate USE bundled up with the triplex on occasion
Yes, they make a 4 wire version of what you have but you may need to remark the cable to indicate the EG and Neutral.
augie47
Tennessee
Note: URD is not an approved NEC wiring method but your picture indicates at least one of the conductors is USE-2 which is approved for direct burial and for use in a conduit.
kwired
Electron manager
NE Nebraska
Since the EGC can (in most cases) be bare copper and still be direct buried, I have no issue with using copper THWN for the EGC here.
I know some will probably disagree.
If that green conductor is aluminum, I say it needs direct burial rated insulation.
Cow
Eastern Oregon
I agree.
If a GEC can be bare, I don't know why an EGC can't be buried THWN.
4 wire mobile home feeder may have been a simpler choice for this installation, but I don't know the circumstances.
readydave8
re member
Clarkesville, Georgia
electrician
Around here, SH's did not stock 4/wire until 15-20 years ago (because "nobody bought it", self-fulfilling statement), so I have seen and done similar installations
