Use Of Materials
What string are you talking about
—— only used white tape with sharpie
Tape can be a PITA to take off. But it is another method.
My guess is that it's what we call a linen tag.
You're talking about a Tyvek tag? I have them but they are too big and expensive for a half hours' worth of time. Tyvek is good for outdoor and permanent use. The ones I use are paper and come from Staples.
-Hal
-Hal
Do they ripe off easy?? Tape can. Be a pain but durable
Up sizing conductors is common like others listed to accommodate for voltage drop. When I did that I would P touch panel door to warn not to increase the 15 amp circuit breaker. The large hospital / research center made two great rules: no shared neutrals and wires from the over 50 84 circuit 120/208 normal & emergency power panels in a new 12 story building had to have #10 THWN copper wire to first JB for every 20 amp on breakers that feed mostly duplex receptacles.
