Use of pull fittings on 13.8kv ?
mwrichard
Greetings, I'm new to the forum.
Electrical Designer (industrial applications, mid level, some instrumentation)been in the business for about 10 years.
Came across an issue a co-worker brought up today on a 13.8kv feeder being re-pulled/reworked.
Someone, somewhere on the job site says conduit pull fittings are not permitted on 13.8kv?
I can't find anything in NEC specifically about this.
Any truth to this?
Thank you in advance!
Mick
Re: Use of pull fittings on 13.8kv ?
Your co-worker is probably correct. Most MV cable will not tolerate the tight bending spaces in a conduit fitting.
Richard
ARe you referring the cable grips used on cable or simething else?
bob, that would be actual conduit fittings.
caj1962, I hadn't thought about it like that. perhaps a mogul BUB fitting??? I'll find out what size conductor he has and figure it out for him.
Thanks for the input!
