USE vs. USE-2
Yes I provided an example of USE that is NOT also marked RHH. Yes encore and I also called it "URD" but that is irrelevant. The point is if you have a piece of this encore stuff, URD/USE/fluffy duffy teddy bear cable - whatever - it says USE-2 on it with NO OTHER NEC recognized rating. That is how this came up was a discussion on whether there was cable marked USE that wasnt also marked RHH.
OK, I apologize, I had to blow up the PDF about 200% to read the fine print at the very bottom of the page, where it had the print legend. You were 100% correct. My bad.
