Some of us work in places where the supply house is 100+ miles away and you do what you have to do until you can come back with correct parts.
That doesn't seem like the case in this scenario.
JAP>
Welcome to the forum, Erika!
Actually, that's Providing the Neutral. You're talking about the grounding electrode conductor(s).
The neutral path, not the ground path. The neutral current pathway must be a conductor or bus, not an enclosure or fittings.
There should be no grounding conductor from the meter to the main disconnect.
There should only be one intentional connection between the neutral and each of the grounding-electrode and the equipment-grounding systems, not "multiple attempts" at grounding it.
It's more accurate to say that the premises equipment grounding system begins where the neutral is bonded to and earthed. The service equipment is directly bonded to the supply neutral up to that point.
Nothing personal, it's just that we're sticklers for accuracy here. We've even had long discussions about having long discussions. It seems the simpler the question, the more complicated the answer.
Isn't something normally needed for a service call. Initial installations/add oin installations, yes. I have a few of them in the shop but probably not a single one on truck. Can't remember last time I needed one either.And this brings us to outfitting your truck stock; I still have 2 add a lugs in my service kit.
I'll second the Welcome.. . . I've been refreshing my knowledge base.
Sincerely,
Erika.
Don't shy away from posting. And keep Article 100 Definitions handy, as the use of the terms in correct context will further the conversation.
I well remember my first posts and the learning curve that accompanied them. It is exceedingly worth the effort! A truly efficient "refresher."
There are people past 50 that still ask that question.Good Morning Al up north...
It's all good. I will... Thank You.
Between engineering with several controls companies along my diverse career a friend suggested I work residential with them, so I did. The Inspectors complemented my panel work as Neat and Organized. Wish I could keep all my own jazz neat and organized.
I found this forum a couple years back and it has been great. I finally got brave enough to post something. I've been doing a lot of study again, intermixed with my own projects. One never knows when I might need to pick up my clipboard and do some estimating, or maybe run away and join the Circus... What should I do when I grow up?
GizmoGirl
"It is never too late to become the person you might have been."There are people past 50 that still ask that question.
Yep! I have to grow old, but I don't have to grow up.And past 60... :thumbsup:
I confronted the EC today and he said that was a temporary solution until he could get the appropriate lug to mount onto the main panel neutral bar.
Thanks to all who have posted.![]()
I had one urgent nighttime call where I bypassed a freq drive to enable a 50horse 480pump for 1M gal swim pool for a swim meet, disco within sight.
������������������...24/7������
I told him, replace the freq
11 years later������ I came back and that pump was still 24/7
no control, no freq... 24/7/365/11$
pool was pretty clean
temp fixes can become permanent
What is the reason to vary speed on such a setup? Is there a reason to have more flow at some times? If not then why not get the right size pump instead of a drive for an oversized pump?I had one urgent nighttime call where I bypassed a freq drive to enable a 50horse 480pump for 1M gal swim pool for a swim meet, disco within sight.
When you have that much water in that big of a pipe, they want to start stirring the water softly, not to bang in on across the line.
As the water gets moving, they ramp up the Hz
Also, once the water is flowing, it only needs a nudge to keep it going.
And there is need for more flow when there is more "organic load"
This is all tied to control systems
If there is a need for more flow at times that is understandable. If it only starts one time, stays at one speed then runs 24/7 for extended time afterward, one may just decide to live with the surge on the line when it starts, really depends on if it is likely to damage anything.When you have that much water in that big of a pipe, they want to start stirring the water softly, not to bang in on across the line.
https://www.youtube.com/watch?v=1YDurhx8QyA
???...24/7?
11 years later? I came back and that pump was still 24/7
