- Massachusetts
Re: Using a Minnie strap/ Conduit Clips as addiquate raceway
In general die cast fittings are nowhere near the strength of steel fittings in either set screw or compression.
A steel coupling will on it's own support another 10' of conduit until you get the support on the new section.
A die cast fitting will usually split open if used like that.
[ September 17, 2005, 12:25 PM: Message edited by: iwire ]
