- Illinois
- retired electrician
Some AHJs will cite the use of a torch to bend PVC as a violation of 352.24(A)...."Field bends shall be made only with identified bending equipment."
Which is why I mentioned not being approved in my post.Some AHJs will cite the use of a torch to bend PVC as a violation of 352.24(A)...."Field bends shall be made only with identified bending equipment."
Carry a rattle can of gray primer with you.Any scorch mark on the PVC would become a violation. Technically it is damaged.
I have a LP radiant heater that I identify as a PVC bender. It is pretty much the only thing it ever gets used for. It works better than blanket heaters in most cases, plus I can use on sites that don't yet have electric power.Some AHJs will cite the use of a torch to bend PVC as a violation of 352.24(A)...."Field bends shall be made only with identified bending equipment."
He sounds like a great guy to not believe.Years ago I was working on a rental that had a retired electrician living in one of the units. Must have done larger jobs because he was saying they had barrels of a heated oil they would place the PVC, in then bend as needed. Anyone familiar with that?
In the Dominican, they have wires in plastic tubing in residential. Apparently they don’t use romex, and only use boxes for receptacles and switches, but not at lights.So I've been seeing a lot of you tube clips that are showing electrical installations being done with what looks like PEX both Red and Blue. Doesn't look like US, maybe Europe or Asia. Is there any talk of listing something similar flexibility as PEX for use as Electrical Conduit. Really look neat and creates an orderly looking install. But could see unions objecting as it would take pipe bender jobs away as it can be done so easily and create the same look.
We have HDPE, is not all that flexible and basically only for underground use. Inside we do have ENT, that is fairly flexible but not really intended to be exposed as it can't take much for abuse.So I've been seeing a lot of you tube clips that are showing electrical installations being done with what looks like PEX both Red and Blue. Doesn't look like US, maybe Europe or Asia. Is there any talk of listing something similar flexibility as PEX for use as Electrical Conduit. Really look neat and creates an orderly looking install. But could see unions objecting as it would take pipe bender jobs away as it can be done so easily and create the same look.
Greenlee had one like that...a vertical tube that you filled with an ethylene glycol water mix and the propane burner heated the liquid. You set the PCV conduit in the liquid for about a minute and then pulled it out and made your bend. You had to be careful you did not have the temperature too high or leave it in too long. If you did the PVC would be like spaghetti and collapse.Years ago I was working on a rental that had a retired electrician living in one of the units. Must have done larger jobs because he was saying they had barrels of a heated oil they would place the PVC, in then bend as needed. Anyone familiar with that?
Love it!I have a LP radiant heater that I identify as a PVC bender.
Sand paper helps tooCarry a rattle can of gray primer with you.![]()
Ok, funny i wasthinking because in the winter if your gloves got wet- it is painful to handle and set big pipe..Greenlee had one like that...a vertical tube that you filled with an ethylene glycol water mix and the propane burner heated the liquid. You set the PCV conduit in the liquid for about a minute and then pulled it out and made your bend. You had to be careful you did not have the temperature too high or leave it in too long. If you did the PVC would be like spaghetti and collapse.
Just pour glue on it...Sand paper helps too![]()
And perhaps collapse less.I'll cap the ends it seems to heat up quicker when I do that.
