Using a rigid box spacer between the service panel and an outlet box
If the KOs don't line up what about using fender washers behind the box to bring it out with screws through them naturally. To me it seems ok if it's only 1/4-3/8 of an inch or so
Instead of trying to figure a way around it, why not just do it the right way instead of like a hack?
Offset nipples are something that every EC should have on their trucks. I personally have never used or seen that box spacer. Never had a need to put anything that close. If I need to put two or more boxes in a row I use straight nipples and 4 locknuts.
-Hal
Nothing wrong with using long enough screw and stacking 3 inches if washers to space it, though in that sort of situation I often cut a short piece of EMT or PVC to use as a spacer. Easier to handle one piece instead of many pieces when assembling.
-Hal
Nothing wrong with the box spacer. faster than close nipple and 4 locknuts, plus close nipple needs bushings. Chase nipple is too close for some raised covers. Often the choice is dependent on what you have. I only keep a few those box spacers as don't seem to need them too often.
Mostly used for surface wiring and maybe a situation where you need 3 or 4 switches but you don't keep any 3 or 4 gang surface boxes on hand, just 4x4's and raised covers, you then can put two 4x4's next to each other with one those spacers between them. I am likely to use an offset nipple for a box next to a panel most the time.
