since I’m an electrician and not a structural engineering i do not know if holds up the roof or not it is an exterior wall that is continuous from water room to electrical room so it seems to me that 250.68b applies to what I was asking in my original question.in any building on the exterior walls your going to have columns in the corners and maybe in the center of the space and then drywall framing between, which in this case happens to be the heavy gauge steel that I talked about, whether it holds up the roof or has columns that go into the ground 8 or 10’ more is irreverent, the fact I have a effective ground path between the cold water pipe and the main electrical panel is the intent of this article
