kwired
Electron manager
- NE Nebraska
- EC
But the problem with that story is the electric skillet likely is not effected other then it doesn't see full 120 volts and don't get as hot as it should. It will be that appliance with electronic controls on it that sees the overvoltage side of the circuit and lets out some smoke, as the skillet will be a low resistance and therefore have less voltage drop across it and the remainder of the applied 240 volts is across the higher resistance item.Wife plugs in her brand new electric skillet into a MWBC that has an open neutral. Smoke comes out before anything is even cooking. Now you (as an electrician) had just added to that circuit and failed to pigtail the neutral and neutral comes loose from a terminal.
Skillet in question lands up beside your head.
Need I say more?
Plus you get no dinner!:huh:
