Hi!
In and older (1974) concrete block house built on concrete slab, no green-wire ground was pulled through EMT that emerges from the slab under the attached patio up into a metal box in the outside of the block wall of the house. The EMT originates from a metal box in a different block wall inside the house, which also has no green-wire ground in it. That box is fed by EMT but no way to know exactly where that EMT originates other than that it must come through the concrete slab somehow from the main breaker box which is on the other end of the house.
Is it safe to use the EMT/metal box on the patio-side of the block house wall as a ground for outside lights and outlets on the patio?
If a standard outlet tester (with the lights on it) shows correct wiring when plugged into an outlet using the metal box as ground, is that enough to be sure that the ground is sufficiently safe for the outside outlet and associated lighting?
Thanks for your help! Nick
