Does NEC allow for the use of fine stranded cable to distribute power into power panels by using a copper wrap (copper tape) on the cable end that is terminated into a lug that is designed for regular power cable? There is an AP Note by an electrical supply company that suggests that using a copper wrap is acceptable. I would believe this if the "copper wrap" was actually a copper sleeve that is crimped on then inserted into a lug. But, I have not seen this copper tape used in this fashion before, so just because there is an AP Note does not make it code acceptable. Is this approved by NEC and if so, can someone point me to that code specific article?
