LarryFine
- Henrico County, VA
- Electrical Contractor
Even a lowly, often-despised non-contact tester would have helped prevent this debacle.
electricalperson said:im talking about blowing a string into EMT conduit i just ran. ii would never blow anything underground into a live panel
LarryFine said:Even a lowly, often-despised non-contact tester would have helped prevent this debacle.![]()
mdshunk said:I guess people do the trick with a female adaptor glued onto a piece of smurf tube, screwed onto whatever connector threads are sticking out. Directs the fish tape out and onto the floor.
SmithBuilt said:I have also heard of the conduit going to a different panel that was still live, not the intended one.
You just can't be too careful.
Let's see:76nemo said:There again, I never have blew strings anywhere. Am I the only one who can say that?
Because the electrician was not following propper procedure for the work he was performing. He was an unqualified person to be performing such work.mike bridges said:A while back an electrician was sending a fish tape into a 20 ft. .75" e.m.t..
This panel was 277/480 and was believed to be locked out and safe. needless to say when the fish hit the main lugs the electrician was shocked and sent to the hospital. My question is why did the electrician get hit when the main over current device tripped when the snake fell between 2 phases?
480sparky said:What I typically do is take a female-threaded PVC cap and install that on the connector. When my tape stops cold, I know I've hit the cap. Then I remove it and can pull the tape on out with needle-nose.
