proxygio
- makati, philippines
If you wanted to get pedantic about it, that's how all single pole circuit breakers in the main panel are wired.
Usually no, not safe. There are a few instances where it could be considered safe, but still not legal.
What are those instances that can be considered "it is safe"? Will it make it safe if you'll cover everything with non-conductive materials
Theoretically the same as "Neutral" in a grounded neutral system? Yes.Hello,
Is it safe to just use "one" phase of the supply and connect it to a load and directly to the "ground" to
form the ckt/loop??
pls refer to the attachment.
Thanks in advance,
Newbie here
No. Not safe. The ground is bonded to other metal stuff throughout the load site. The neutral is isolated from all that metal stuff (no neutral-ground bonds beyond the main disconnect).Hello,
form the ckt/loop??
Thanks in advance,
Newbie here
Not beyond the bonding jumper.Theoretically the same as "Neutral" in a grounded neutral system? Yes.
Hello,
form the ckt/loop??
Thanks in advance,
Newbie here
Without getting down to the conductor identification rules in 200.7 and 250.119 what code rule really says we can't do that?...
"Legal", definitely NO! ...
Huh, you know what? You may have identified another of my internal "myths". It was my gut reaction, but when I think about it, why is that different from what the circuit would look like on a corner grounded delta 3 phase system feeding a single phase load? You are right in that identification would be crucial, but not illegal to do it? I'm now questioning my long held belief that you can't use the ground connection as a current carrying conductor. It was the way I was taught as an apprentice doing residential work, but when I got into industrial work, I guess I never made the leap of logic to recognize the inconsistency.Without getting down to the conductor identification rules in 200.7 and 250.119 what code rule really says we can't do that?
I know we shouldn't be able to do it, I just don't know of code section that actually says you can't use an EGC as grounded conductor.Huh, you know what? You may have identified another of my internal "myths". It was my gut reaction, but when I think about it, why is that different from what the circuit would look like on a corner grounded delta 3 phase system feeding a single phase load? You are right in that identification would be crucial, but not illegal to do it? I'm now questioning my long held belief that you can't use the ground connection as a current carrying conductor. It was the way I was taught as an apprentice doing residential work, but when I got into industrial work, I guess I never made the leap of logic to recognize the inconsistency.
How about sections dealing with:I know we shouldn't be able to do it, I just don't know of code section that actually says you can't use an EGC as grounded conductor.
