Do you put that in your Quote/Proposal that if needed you will splice conductors in an attic or crawl so that you can use up left over cable ??
Nope, I don't make mention of it because I don't actually know how I will do the installation until I get to that point.
Let me ask you something, if you are using conduit and you have more than 360 degrees of bend in the run, do you fight the conductors through each pull point trying to keep from using a splice? If so, you are probably risking damaging the conductors more than you would by splicing them.
With that said, if you feel that making a splice is short changing your customer, then by all means, always use a continuous unspliced run.
I personally won't and don't worry about it.
Roger
