Bugman1400
- Charlotte, NC
Bugman,
I disagree! There will always be a circulating-current even if grounding-connections are separated! Even if the generators are "identical!" Circulating-current magnitude is based on the relative differences in generator parameters and operating conditions!
Regards, Phil Corso
If the grounding is impedance grounding, the circulating current between the generators are minimal. What sequence current are you referring to for circulating current?
