mbrooke
Batteries Included
- United States
- Technician
No. I meant that regular 14 2 doesn't need twisting to reduce magnetic fields.
I disagree. Twisted conductors are always better with EMF then flat conductor side by side.
Having the conductors in close proximity still is much better then routing each conductor of a circuit away from each other - like was common with knob and tube wiring systems. Twisting them around each other is better yet.I disagree. Twisted conductors are always better with EMF then flat conductor side by side.
I know they are better, but they're not THAT much better.
The magnetic fields were measured with a try-field meter. The only place any magnetic field showed up was near the wall behind the refrigerator. I have to pull out the ref. to put some shielding material behind it to absorb the magnetism. The other fields were measured with the multimeter doing the body voltage measurement. The field was reduced 75%. The rest will have to be corrected with shielding paint. Y-Shield. This does not work for magnetic fields, but does additionally cover RF.Was the reduction in static or magnetic fields? How are you measuring them?
You have made the decision that it will be easier to shield the wall behind the refrigerator than to correct the the wiring error (probably within the wall) that is causing it?
Or is it coming from the refrigerator?
The body voltage test is not a good measure of the field you actually sense if the ground lead you test against does not represent the potential of the floor, walls and other objects surrounding you.
It is more expensive, but an actual E field sensor with probes is more representative of what affects your body.
mobile
Refrigerators tend to produce a magnetic field. There is material that you can purchase from Less EMF and other companies that can help block and absorb the magnetism. The panel and the ref. are usually a source for magnetism even when there are not wiring errors.
