recently testing emerg gen system we shut down power in mdb to simulate power failure to start gen. the sequence we used was to open mdb 2 switch , mdb 1 sw , then main, noticing some arcing and sparking . when this occured it took out 3 fuses at utility ( incoming which is 15 kv) and 2 fuses in main sw gear? the gen worked fine . what could have caused this ? this test was performed a week earlier without any problems ? also what is procedure to drain off fuses in gear before working on it?
