As far as I know with new 480V Service entrance the utility transformer can either be customer or utility owned. Most of the time for 480V services I see the transformers as utility owned but in a few cases I have seen ones that have been customer owned.
Is there a determining factor for deciding whether a transformer will be utility owned or customer owned for a given service entrance?
If the transformer is utility owned then the metering point will be on the secondary of the transformer (metering cabinet or customer Switchgear) and the service entrance would be considered on the transformer secondary. If the transformer is customer owned then I'm guessing that the metering point will be on the primary and the service entrance will be considered the primary of the transformer. Is this correct?
What about from a primary breaker/switch perspective for isolating the 480V secondary equipment. If the transformer is utility owned with the metering on the secondary I don't believe there is anywhere on the primary that the customer can install a switch breaker be able to isolate secondary when needed and therefore will require the utility to open their switch for any sort of outage. With customer owned transformers I'm assuming there is more flexibility to install a primary switch to give the customer the opportunity to isolate system for outages when needed?
