tonyou812
- North New Jersey
Does anyone know how deep most utility poles are in the ground? I have to do some digging around one and Im just curious how deep they are in the ground.
i think its something like 1/3 of the total length of the pole is in the ground.
I do not believe the answers you are getting. Look at the pole brand to see how tall the pole actually is instead of guessing. Then take 10% the height of the pole and add two feet. A 35'-5 pole should be set 5? feet deep. A 65'-2 pole should be set 8? feet deep.Does anyone know how deep most utility poles are in the ground? I have to do some digging around one and I'm just curious how deep they are in the ground.
Electric utilities do not follow the American Electrician's Handbook but they do install poles correctly. I suspect the reason for a greater depth is that electricians do not normally set poles and don't normally tamp properly. I don't have them at my fingertips anymore but there are actual standards that state what I just posted. That little formula holds true until you get into transmission size poles somewhere around 85' or 90' tall. :smile:American Electrician's Handbook recommends setting poles 1/5 th the length of the pole in the ground.
Thank you. After 38 years doing engineering work for an electric utility and now doing consulting work for the codes and standards area, I do know how deep to set a pole.Charlie absolutely nailed it in his first post, 10% + 2 feet rule.
