Utility power indicator light
nizak
Looking for suggestions on setting up some type of indicator light that would show when utility power is on.
I have a customer who lives in a remote location without any neighbors, street lights, etc. It’s difficult for her to know when utility power has been restored.
She has a portable generator she uses with a load center interlock.
Is it code compliant to just tap off one leg ahead of the main breaker for 120V and put a indicator light next to the load center?
Thanks
IMHO, I would just install an led lamp next to panel. Also, since most meters are smart meters, one could also look at the smart meter. 🙂
As I understand the OPs post is that the customer turns Off her Main when the generator is used. Interlocked. She has no power to tap from unless they make a connection prior to the Service disconnect.
Better way would have been to have the Gen run only a small subpanel with the needed loads and leave the Main breaker on. Hindsight.
Any tap 'ahead of the main' needs to be itself suitable as service equipment; with suitable OCPD and the like. It certainly can be done.
I've used (only once) and like the reliance controls sensor described in post 4. Essentially it is a 'non-contact' voltage sensor built into a box with a loud buzzer. You wrap the sense wire around the outside of one of the mains cables; there is no galvanic connection to the mains conductor, just induction through the insulation.
-Jon
