charlie tuna said:i'll throw a wrench into the gearbox ------ how do you get around exceeding the voltage rating of the disconnect switch??? the output of the drive is above 600 volts!!!!!!!!!!!!!!!!!!!
benaround said:You can always add inter-lock contacts at the service switch to open the
vfd side at the same time, in case of accidental opening of service switch.
It's far less expensive in the long run.
If that is correct than how can we use standard 480 volt motors and standard 600 volt wire?i'll throw a wrench into the gearbox ------ how do you get around exceeding the voltage rating of the disconnect switch??? the output of the drive is above 600 volts!!!!!!!!!!!!!!!!!!!
