7. The applicant certifies to the following: N.J.A.C. 13:31-1.17 (c)
3. A certification that the applicant is familiar with and will comply with the applicable National Electrical Code
provision requirements, including, but not limited to Article 800 (communication circuits) and the regulations of the
New Jersey Department of Community Affairs and that the applicant will be responsible for obtaining any required
local permits and inspections for all work;
4. A certification that the applicant shall not perform the following work unless or until an electrical contractor’s
business permit is obtained from the Board:
i. Wiring defined by the National Electrical Code as service conductors (the supply conductors that extend from
the main or transformers to the service equipment of the premises supplied, feeder (all conductors between
service equipment or the source of a separately derived system and the final branch-circuit overcurrent device),
and branch circuit (the connection between the final overcurrent device protecting the circuit and the outlet/
appliance). Wiring between power supplies integral with telecommunication equipment and the telecommunication
equipment is not intended to be prohibited;
ii. Telecommunications wiring from telecommunications equipment to power operated controlled equipment; or
iii. Installation of work in hazardous/classified areas as defined by Article 500 of the National Electrical Code.
Classified areas are those in which hazardous liquids, vapors, gases, dusts and fiber are normally present (Division
1 locations) or may be present due to maintenance or equipment malfunction (Division 2 locations); and
5. A certification that the business shall not subcontract telecommunications wiring work to a person or business entity
not having a business permit or a telecommunications wiring exemption issued by the Board.
