QES
- California
any one verify the voltage/current on the system or device after turning off power(off breaker) before performing any service on it. you think its a redundancy?
QES said:any one verify the voltage/current on the system or device after turning off power(off breaker) before performing any service on it. you think its a redundancy?
got_nailed said:With the control boxes I work on I will flip the breaker at the panel and use the disconnect at the equipment. And yes I do test all the power supplies once I open the boxes.
One day I burnet my wedding band in to my finger. You only have to do something like that one time before you start to triple check stuff.
He has it right. You no longer do a simple voltage check as we know it. The new proceedure is called "Read-Verify-read"We always check before & after
davidr43229 said:The new proceedure is called "Read-Verify-read"
