tishjoh
- Newberg, Oregon
I am new to this so if this has been discussed before, please point me to it.
I have a customer that wants to use a small AC Inverter/VFD for:
1. takeing 230v 1 ph and running a 230V 3 ph 5 hp motor. (which the specs say it can do it.
2. use the VFD to control the motor speed for a wood lathe in a wood shop
Question #1 The documentation for the VFD says the power wireing must be shielded. It does not specify if this is between the VFD and the motor and/or the power input to the VFD. Any thoughts?
Question #2. I have seen in a couple of other discussions here, mentions of the motor having to be inverter rated if being used on a VFD, for clarification this is a seperate rating from the duty (continous, intermitant) correct?
