Fnewman
- Dublin, GA
- Sr. Electrical Engineering Manager at Larson Engineering
In an industrial plant there is an existing conveyor transporting solid material at a constant rate 24/7, 350 days per year. Motor is 100 HP, 460 v, IEEE 841 design. Based on the quantity of material required by the process, the motor load is only approx. 45% of FLA. The system was designed like this because on rare occasions for fairly short periods the conveyor needs to transport twice as much material. So now the possibility of installing a VFD has been raised, along with the question of how power consumption would, or would not, vary. So, how would the total input power change between the two arrangements given that the amount and rate of material transported will be the same.
