drktmplr12
- South Florida
- Electrical Engineer
This is a shot in the dark, but quick enough to ask.
I know this is a loaded topic!
I am tasked with preparing a technical document explaining why water production wells were failing and restarting while running on generator power during and after Irma. This occurred in Southeast Florida.
I am not asking the forum to provide me a dissertation, that is my job. I am more looking for simple (and probable) theories to consider from the informed opinions on the forum. I will provide any additional information that is requested, granted I can easily get my hands on it.
Thanks in advance for anyone who takes the plunge here.
My current theories:
FPL AB 486V, AC 486, BC 486
Gen. AB 514, AC 514, BC 514
Wacker G125 Prime Rated, 98/122kVA @ 0.8 pf
Well 29, 175 HP
FPL AB 483V, AC 483, BC 483
Gen. AB 480, AC 480, BC 480
CAT 350/437kVA @ 0.8 pf
- Process conditions caused wells to experience overload conditions, causing VFD protections to trigger. The motor cooled down and automatic restart triggered. The cycle repeated until operations intervened.
- Generator became unstable due to harmonics resulting in overvoltage conditions. The VFD would fault, generator would stabilize and automatic restart triggered. The cycle repeated until operations intervened.
- Failures were observed while wells were operated with portable generator power.
- Wells may or may not be on same utility feed.
- Same behavior at all wells with VFD (Altivar 61)
- Well controls have been equipped with VFD’s for approximately 5 years.
- Wells controlled by VFD have been operated on generator power previously and without incident.
- It has proven difficult to repeat the behavior with the same generators.
- Data gathered includes generator nameplate data, electrical data (voltage, power, harmonics), VFD configuration parameters and flow measurements.
- The configuration parameters one VFD was downloaded to be inspected for possible causes for VFD failures.
- A fault log for one drive was obtained, which revealed a series of overvoltage faults without time stamp. These could have happened before, during or after the storm.
- Automatic restart is enabled.
- A Dranetz Power Platform 4300 Spectrum Analyzer was used to measure voltage and harmonics present at each site.
Well 29, 175 HP
