An industrial facility has (2) 100hp motors and their breakers are overheating and failing. A specialist was brought in for load monitoring and is stating the system is seeing harmonic disruptions that are the cause of the problem. The local utility acknowledges the harmonics but states they are within their allowed parameters. The specialist is stating adding a VFD to the motors will mitigate the harmonics. Ownership does not want to spend the money unless it will solve the problem. The current starting method is across the line.
Will a VFD mitigate harmonics? Does a specific type of VFD need to be specified?
