ptonsparky
Tom
- EC - retired
Need a hint on what parameter(s) needs to be set in order for drive on a submersible well to ramp up just a bit before shut down when pressure has been maintained for x amount of time. This allows the drive to shutdown and "sleep" until pressure drops below y. No sense in having the pump run if it isn't moving adequate water for cooling the motor. I have done this before but don't remember which drive or what parameter.
Fire away with info for whatever drives you use because something may ring a bell.
A few years ago I did not think I would see to many of these but have worked on 4 different brands in the last three days. I also didn't think I would work on motors when I was forced to take a motor rewind course in school.
