Jim1959
- Longmont, CO
I haven't worked with VFD driven motors a lot, a spec I'm bidding calls for shielded power conductors to the motor. What is the purpose of the shielding?
To stop the switching frequency affecting other conductors.I haven't worked with VFD driven motors a lot, a spec I'm bidding calls for shielded power conductors to the motor. What is the purpose of the shielding?
Will shielding still have a positive effect if the conductors are in a dedicated metallic conduit?
Don't use THHN for the motor leads in conduit.
Why not?Don't use THHN for the motor leads in conduit.
Thank you Mr J.Some of this I know you know Besoeker, I'm explaining it all for those that don't.
THHN uses thermoplastic insulation, liquid PVC applied to the wire and heat set to solidify. In that process, it gets tiny voids in it, bubbles if you will. When working with sine wave power, these are irrelevant. But on the output of a VFD, the DC pulses cause capacitive coupling and standing waves that reflect back and forth and increase the voltage. That higher voltage subjects the insulation of the wires to corona discharge stress. The voids in the PVC reduce the cable's ability to withstand this and eventually it fails, leaking to ground or to adjacent cables. This is something that has taken years to come out but I have personally seen it now several times, starting about 5 years ago, on installations that were 5-20 years old. One time when I had to pull the cables out, you could see the burn-through marks at regular intervals, indicating the wave length of the standing waves. It was interesting, but of course represented the failure of the THHN.
The better choice being touted now is XLPE insulation, which you get with XHHW cable. It's essentially heat shrink tubing put over the wire and shrink into it, no voids. It typically has higher voltage ratings too, 100V or even 2000V.
Did a lot of vfd work in mid 90's always used mtw on load side because that's what the old timers used never asked why.
Please excuse my ignorance. What is mtw?
THWN, or USE AL is ok, but not THHN?:dunce:
More likely is that you have your configuration set to display ten posts per page and you hit the, fortunately infrequent now, vBulletin bug that prevents display of the second page of a thread until after you have posted to it.and I thought I asked this question before any of the responses above. My connection must be dang slow or you guys are super fast.
Thank you.
Machine Tool Wire. A type of wire which is, I believe, characterized by high strand count for high flexibility and a tough wear resistant flexible insulation.
In that respect it would be similar to DLO (Diesel Locomotive) wire and is NOT a wire type found in NEC tables for building wiring.
It can be used for building wiring if it is also categorized as a different UL wire type that is in the NEC tables, or it can be used for internal wiring in a product, listed or unlisted, that is wired as a unit by the manufacturer and is subject to different evaluation criteria.
For example, based on its insulation and construction some MTW may also be listed as TFFN (fixture wire) or as THHN and can be used in building wiring where Chapter 3 allows those wire types.
