CPS Elec.
- Bemidji, MN
How do you know if a motor is compatible with a VFD?
If they are 40 years old the probability is that they were not made to work with VFDs. A common problem, and one that I've met a few times, is the very fast switching edges (the high dv/dt) that modern VFDs present to the motor. Winding insulation failure can, in my experience, occur in a matter of a few weeks. There are ways of getting round this. Reactors or filters between the VFD and the motor can mitigate this problem.The motors in question are up to 40 years old and I've had a hard time locating any data sheets, is there any other way, possibly something stamped on the nameplate?
These days some motors have an insulated bearing at one end to prevent circulating currents due to asymmetry.Bearing damage is due to magnetic imbalance in the stator and rotor and the resultant voltage buildup is much greater at higher than synchronous - 2-8kHz carrier frequency - and non-sinusoidal supply. The leading switching edge is not helping this either. It can be easily remedied by discharge brushes on one end. The voltage buildup is not a static charge though and it is due to the bearing lubrication forming the dielectric, insulating film on the race surface, pretty much identically to the EDM process.
Interestingly enough older motors were more balanced magnetically than motors produced today to high efficiency standards with random winding and and tightly packed stator slots.
This is an excerpt from a specification of one we installed fairly recently:
Extras Included
45X Heaters (voltage to be confirmed) terminated in the main terminal box
Separate cooling
1024 pulse tacho encoder
Insulated bearing
Routine test report
It's from one of the mainstream motor manufacturers.
I can see that as being the easier option on a refurb. The one we did recently was a new installation and, at 180kW, not very big. Insulated bearings have been around here for quite a while too. I have a Gambica technical guide on bearing currents from some years ago and it mentions insulated bearings. But I don't know how many of VFDs we've supplied have them fitted to the motor - mostly we don't supply the motorsIt has been available in the past 10 years or more, primarily on MV and larger frame LV motors. I was refurbishing an existing 800HP motor with an ASD and it was suggested by the OEM of the motor. Instead I've installed a grounding 'brush' - a beryllium/copper leaf riding against the shaft and it has been dancing eversince.
Appreciated.The addition of the isolated bearing was discussed in the IEEE541 meetings, I don't know if it ever made it in, I'll check when I am in the office.
Nor have I but this an example of what it looks like:I must have been lucky over the years. Never ran into the bearing problem. have heard about it, but never ran into a case where it actually happened.
Have heard about it and then run into one on an unexpected size. A 10HP motor failed this way.
The tale always was that it happens on large motors, several hundred HP or larger. Maybe because only on those sizes would you spend the money AND have the available room in the first place, to install bearing isolator sleeve.
BTW I thought I had a copy of the IEEE541, alas I only have the 841.
"[FONT=Arial,Bold][FONT=Arial,Bold] 5.3.2 Adjustable speed drive (ASD) Supply
i) Shaft-to-bearing voltages and/or currents resulting from common mode currents flowing throughstray system capacitances to ground via the bearings. These currents are induced from the ASD?shigh rate of change ([FONT=TimesNewRoman,Italic][FONT=TimesNewRoman,Italic]dv[/FONT][/FONT]/[FONT=TimesNewRoman,Italic][FONT=TimesNewRoman,Italic]dt[/FONT][/FONT]) of output voltage"
[/FONT][/FONT]
