LarryFine said:
If you look at a reversed 3-phase system as 240 degrees instead of 120, it's still the same thing, only with the rotation direction reversed.
Yes, I saw this.
#1) I traced (A,C,B) with my finger on a circle with 3 points, it went perfectly backwards.
Then I tried to see what this load rotation and opposite svc. phase rotation did together.
#2) I traced both phase rotations on the same diagram with my fingers, circling opposite directions, and saw the xfmr firing (B,C) at the same time, before realizing the svc. won't do that.
#3) When I finally realized one finger would have to trace a mirror image, since C&B coils trade angles to run opposite phase rotations, I was seeing DC or VFD's --240 degrees apart-- and forgot about #1)
#4) By the time I realized no matter which order a tripods legs hit the ground they alway circle 120 degrees apart, I was seeing 5th harmonics on (A,C,B) phase rotations, and forgot about VFD's.
#5) So, do I get it yet?
Overheating with 5th order harmonics is a product of DC simulated 6-pulse phase rotations using VFD's, and mixing up 3-phase rotation will always hit AC motors 120 degrees apart, changing the direction of the motor only?
Or are 5th order harmonics also inherent to a standard induction motor design with a negative phase rotation?
