1964element
- Chicago
Feeder wire looks small in the picture, but I'm sure it's OK,wonder if its a sub protected by ??
Sent from my E6782 using Tapatalk
I cracked the book. He is right. But something rang a bell in my mind. I cracked the book some more, and confirmed what I remembered:
- The authors of Article 110.26(A)(3) apparently believed that 2 meters was equivalent to 6 feet, 6 inches.
- The authors of Article 240.24A apparently believed that 2 meters was equivalent to 6 feet, 7 inches.
Go figure! :roll: For the record, 2 meters is actually closer to 6 feet, 6 and 3/4 inches.
As long as working space is maintained with the door open, flush mounting the panel dead front cover and then covering that with a raised surface door instead of a flush door should be code compliant. Or just hand a picture over it!
All flush mounted panels are technical violations since you have sheetrock and studs in the dedicated equipment space.
What's the blue coil, looks like cat5?I try to explain a contractor that this is violation. What is your opinion about it?
While I agree that the intent of 110.26(E)(1)(a) is not to prohibit essential structural elements such as framing and wall materials in the dedicated space, the exception thereto for permitting suspended removable-panel ceilings in the "zone" implies otherwise.I thought the foreign equipment that is not permitted in dedicated space requirements, is supposed to refer to equipment such as plumbing/HVAC, as opposed to structural materials. Equipment that can leak, or that may require its own operation maintenance, rather than material that forms the general building.
Otherwise, this makes suspended ceilings and housekeeping pads a violation. Or knee bracing for a free standing structure that supports the electrical equipment.
A similar situation occurs often here where you have an exterior wall of 8" block 1-2 ft or so high with a 2 x 4 or 2 x 6 plate and wall on top causing the front of the panel to be 2-4" back from the front of the block. It is routinely overlooked by the inspectors.
Sure it's a violation. A ticky tack one at best. I would have no complaints if I had to work on that panel.What the OP pictured is a technical violation, tho there ought to be some leeway to recess one up to say 2" for asthetics reasons - I wonder if that proposal ever comes up to the CMP.
In reality, the amount of crap that winds up in front of panels (shelves, closet hanger rods, washing machines, safes, etc) is far more a pitb than the panel being recessed an inch or two would ever be.
This one gave me pause. First off, from a perspective of the intent of the NEC, I wouldn't have a problem with this.
This is a violation that should have been caught before any wires were attached or any wall finishes were installed. This is going to be a tough one to fix (presuming the local AHJ throws a flag on this play).
I would say the pictured installation violates the exact intent of the rule.
I would not say a standard recessed panel on a flat wall violates the intent.
I said the intent of the NEC not the rule. But that said, don't you feel the intent of the rule is to prevent creating unsafe conditions where a person has to lean over or otherwise contort to work on said equipment?
I suggest leaving it to the inspector: if he doesn't like it then he can take the heat from the GC instead of it falling on you.
I would think a better way to handle this is to let the GC know about it long before the sheetrock went up.
