"Nothing has to flow into the ditch, because that's not the goal of our water in this analogy." LOL:grin:
So a straight 240 with no neutral requires a balanced load,for instance most electric water heaters. I think I understand that part. It goes from L1 through the load to the power source at L2 then turns around and goes back the other way, through the load to L1.
http://cast.csufresno.edu/agedweb/agmech/graphics/ElectricityAg4.gif
In 120 volt It looks as if the power is being pumped out in L1 through the hot wire and sucked back in through the hot wire when the switch is off for the light. when the light is turned on it appears that the hot is pumped out through the receptacle and light and carried by the grounded cond. back to the power source and then sucked back in.
I know I'm missing something or getting confused with this concept somehow, gonna reread some chapters and see if it clicks.
roger said:There can be no unbalanced current flowing if more than one ungrounded conductor is not connected to the neutral.Roger
