voltage at breaker when it's Off
Phantom voltage it has to do with the meter you are using. When in doubt utilize a wiggy type tester or even a simple light bulb set up.
Change the resolution manually.
Realize the issue exist and work with in the restraints of the meter or do as noted above.
