The caps are not necessarily equally split, and even if they were, there is still current through R1. And, it doesn't take much voltage to drive the opamp output to the rails.Originally posted by steve66:
Looks like you almost have it Rattus, but I see one problem. The capacatiance between the device and the Line (C1) is a stray capacitance, right? Same for the (C2). So C1 is equally split to both sides of R1. And C2 is also equally split to both sides of R1. So it looks like the voltage will always be zero across R1. I don't see any way to make the capacitance non-symetrical to get a voltage across R.
I guess I should have taken the time to read the link lauraj gave.
Steve
Yup, the wet paper is conductive. It forms a shield between the hot and the probe. This reduces the field to the point that the tic tracer cannot recognize it.Originally posted by lauraj:
Physis, that was NM, not MC. We do a demonstration here, where we've got a piece of romex with a cord cap on it, that has been soaked in water, so the paper inside is nice and wet. Plug it in to an outlet and the tick tracer will not pick it up. Now can anyone explain why that happens?
I wasn't saying Rattus was incorrect, just that a small piece was missing. If you think about it, the resistor is in the middle of a bridge of capacitors. Think of a wheatstone bridge. You have two capacitors on the top with equal values "C1", and two capacitors on the bottom with value "C2". With a resistor across the middle, the voltage has to be zero.Without (still) having given it much thought, I tend to think that Rattus is correct Steve. But really I'm just going with what feels intuitive at the moment.
That's not so easy as Rattus says I don't think.By lauraj:
Did I miss something?As for C2, you can say it is unnecessary, but it is there nonetheless, so you had better include it.
Not if you read my schematic.By Rattus:
without C2, you would have an open circuit
Sam, decoupling caps are used on supply buses, not on opamp inputs. The whole thing "floats"; there is no ground reference as such.Originally posted by physis:
Wait a second, C2 would decouple the positive OP amp input from Ground. That makes sense.
Did you take one apart Rattus?![]()
