- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: voltage drop at receptacle
So I attempted to do everything reasonable to open the neutral to that smoke. I plugged in a vacuum, rated 12 amps, cranked it up, and watched my meter. The voltage dropped, but not below...113V, if memory serves. I did notice (with my new incentive for poking around) that the voltage didn't drop as much on outlets closer in the circuit to the panel.
Is that voltage drop in action? Is that essentially what this inspector's meter does? And how much is that!??
This reminds me of a similar situation. There was a nice older lady complaining that her smokes were intermittently chirping, waking her in the middle of the night. Not false alarm, but "low-battery" chirping. Couldn't find anything wrong, so I replaced the smoke (obviously, she'd already swapped batteries) and crossed my fingers. Two days later, same deal. After hours of thinking on it and a trip or two more, I started to think, maybe I've got some bizarre open neutral problem that is allowing the LED to light, but not enough juice for the smoke's function, draining the battery: Needless to say I was grasping at straws at that point.Originally posted by jimwalker:
With no load he would read the max available.Sort of like long test leads.Then apply load and would get a lower reading.Is this guy testing every outlet ? How many inspections does he get done in a day ,2 ?
