Was called out for lights flickering. I turned on the Fridge,Washer machine, Microwave, toaster, coffee pot and the lights did not flicker. They told me it just started 3 months ago. I started testing at the Meter main, The garge feed through panel, Panel in the houses and each individual breaker. The A phase was 119 and B was 117.
I was about the go and come back when their issues starts again. Then the Washer machine started agitating. Then the lights started to flicker it got worse with time and I went to check the voltage and it was, A phase 144 B phase 105 fluctuating on the Main breaker in house panel, I went to the Feed Through panel that is feed from the meter main and it was doing the same.
I went back out to the Meter main and the I could not see the voltage difference it was 121/124 a little higher then before.
I hocked up 2- 15 watt bulbs to each phase at the Meter main since I was not sure if I was missing the flickering. I Stood and saw the lights in the house flicker while the outside lights did not.
It was flickering lights on either phase inside.
All the times I ever came out for this type of it was an issue with the POCO but they already came out and tested.
Since the Washer was effecting the Feedthrough Panel on the line side but not the load side of the Meter main. I think I have an issue with the Wire feeding it. Its urd wire and we live in a extremely wet area.
