Voltage drop calculation (finding distance of existing circuit)
FWIW, I have absolutely no idea what the answers could be. This is way over my pay scale.
I already started working up a #2 AWG example, but I’ll also do yours. Give me the ambient temperature as well as raceway material if any.
Depends on the circuit. Give me some specifics and I’ll gladly calculate the difference.
I don't have any specifically.
I used to use VD=IR for sizing cabling at marinas (shore power for boats). I was just curious how close the real world would be to those calcs. It doesn't really matter for me now, but I'd like to know.
210313-1400 EST
Note: the original post was with a hair dryer, basically a resistance for the most part. Dsg319's results were generally correct, and more accurate instruments would likely have produced somewhat better results. Note: that he used a resistive load so that reactive loads are not of concern.
So I setup some crude experiments. The wire is Romex #14 copper of a nominal 50 foot roll. The room temperature loop resistance should be about 0.253 ohms from published wire tables.
With my General Radio LRC bridge I measured 0.242 ohms at DC, and 0.275 ohms at 1000 Hz. On the same bridge on low Q inductance I read 13.5 microhenrys at a low Q of 0.31 . This inductance at 60 Hz has an inductive reactance of about 0.005 ohms. Small compared to either AC or DC resistance measurements.
With a load current of 11.7 A thru the cable the voltage at the load end was 109.0 V and at the input end was 112.4 V, or a change of 3.4 V for the loop. Thus, the cable loop resistance calculates to 3.4/11.7 = 0.29 ohms. This is reasonably close to the 20 deg C table value of 2.53 ohms per 1000 ft. And because of the way the test was run there was some cable heating.
See attached.
  • Voltage Drop Calculation Method Comparison.pdf
Some day I hope to do basically same test except with a known footage just for giggles to see how close it could be. And also could include wire resistance as well as the load.
(Although I have recently learned it will not nearly be accurate with all the considerations to take into effect, raceway, temp, and I’m sure many others ). I would just like to see if it’s even within the ball park.
Shop I work at actually has a greenlee tool that can measure conductor lengths. Can’t think of what it’s called right now.
Wish I would have been this interested into electricity when I was wasting mine and the teachers time at school! Only to know a few years down the road I would fall in love with it, BUT thank God I take time to learn now, no time to learn like the present!
