I have a garage 450 feet away from the electrical service. I am figuring voltage drop. This is a storage garage with a few lights and outlets. Not totally sure what will be used in it. A vacuum cleaner? Circular saw. Maybe one day a electric heater. I understand the formula to figure it out but what values do I use. If I do a load calc on the building do I use 120 or 240 volts. Do I do both and see which one gives me a large conductor size.
Should I just assume one 20 amp 120 volt load? I get confused when there is so much unknowen. Thanks
For me, I would put the scratch pad, pencil, and calculator away and run 2,2,4,6 mobile home feeder cable, tag it to a 90A breaker and be happy that I did a good job and gave the customer the best bang for the buck considering.....
1) Take electric heat and A/C out of the equation and you use more power in the morning making toast and coffee while the girls house use the hair dryers and curling irons in the morning than you do the rest of the day.
2) I ran everything electric I could in my house one Saturday afternoon just to see how much load I could pull, electric clothes dryer, double electric oven, microwave, stereo, hair dryers in two bathrooms, every light in the house,....... put my ampmeter on the main and I topped out at around 78A.
3) Back when I was framing houses we would run three to five skill saws, a table saw, and an air compressor off a temp panel with two 20A breakers.
4) Most anything that every day people use can tolerate more that 10% voltage drop.
